Its confirmed. Thanks Ariyap!
Dustin Burns
ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022-2023
Original Message:
Sent: May 09, 2023 06:53 AM
Subject: Adjust RF on an Individual AP
Thanks. We're still on 8.7.1.10 and plan to upgrade to 8.10 in a few weeks. I'll take a look at this then.
Nathan K
Original Message:
Sent: May 08, 2023 07:45 PM
I thought there was per AP overide in AOS 8.8 that you could make use of through WebUI. Perhaps you can check that.
Original Message:
Sent: May 08, 2023 10:39 AM
No just CLI.
Dustin Burns
Original Message:
Sent: May 08, 2023 10:24 AM
Thanks. I knew you could do it but wasn't sure exactly how. We're running AOS 8. Is it possible to do this in the GUI as well? I couldn't find the right view.
Nathan K
Original Message:
Sent: May 08, 2023 09:19 AM
You can configure this like the screenshot below. You can link to different radio profiles on a per AP basis.
IMPORTANT!!! Create new radio profiles for this. Manipulating an existing profile can effect the AP-groups that are using it.
Dustin Burns
Original Message:
Sent: May 08, 2023 07:52 AM
Is there a way to adjust the RF settings for, 2.4 and 5, on an individual AP without affecting those same settings on an entire AP group? We have a few APs that we'd like to keep in the same AP group but need higher RF settings.
Thank you.
Nathan K
