Admin Privileges to only login to Clearpass Insight
  • 1.  Admin Privileges to only login to Clearpass Insight
    Posted Oct 06, 2016 10:24 PM
    Is there admin privileges in Clearpass only allow the user to login into Insight, and not other module? I have read, but seems like nothing like that.
    Thanks in advance.
    Crone
  • 2.  RE: Admin Privileges to only login to Clearpass Insight
    Posted Oct 06, 2016 10:33 PM
    In ClearPass Guest, you can create an operator profile with only access to
    Insight. Then create an application authentication service for Insight with
    your different access policies.
  • 3.  RE: Admin Privileges to only login to Clearpass Insight
  • 4.  RE: Admin Privileges to only login to Clearpass Insight
    Posted Oct 06, 2016 10:48 PM
    Hi Tim,
  • 5.  RE: Admin Privileges to only login to Clearpass Insight
    Posted Oct 07, 2016 03:29 AM
    You can create a custom admin privilege in CPPM for access to Insight only.
    Create new and call it 'insight'.  You'll have to give something on the Policy Manager side, but just give as little as possible.
    And then give full access on the Insight side.
    Then create a new admin user and assign that privilege.
    Navigate to https://<clearpass>/insight and login with that account.
  • 6.  RE: Admin Privileges to only login to Clearpass Insight
    Posted Oct 07, 2016 04:03 AM
    Hi Michael,
    I manage to create custom admin privilege using XML, and only give RW to dashboard. But how to edit the privilege as per your screenshot? I dont find any edit button here.
    Crone
  • 7.  RE: Admin Privileges to only login to Clearpass Insight
    Posted Oct 07, 2016 04:07 AM
    Sorry manage to find it.
  • 8.  RE: Admin Privileges to only login to Clearpass Insight
    Posted Oct 07, 2016 04:08 AM
    Forgot to mention.  That capability came out in 6.6
  • 9.  RE: Admin Privileges to only login to Clearpass Insight
    Posted Oct 07, 2016 04:10 AM
    Yes, just saw the difference between 6.5 and 6.6. In 6.5 I can edit the admin privilege.
    Thanks Michael!
  • 10.  RE: Admin Privileges to only login to Clearpass Insight
    Posted Oct 07, 2016 04:13 AM
    Yes, in 6.5 you can edit them of sorts.  From memory, you can't create a custom one specifically for Insight only.
