ADP multicast address
  • 1.  ADP multicast address
    Posted Jan 19, 2014 12:21 PM
    Some Aruba documentation says that  ADP uses 224.0.82.11, other documentation says that the address used is 239.0.82.11 - which address is the coirrect one?
  • 2.  RE: ADP multicast address
    Posted Jan 19, 2014 12:31 PM
    Where do you see it one way and where do you see it with the other?
  • 3.  RE: ADP multicast address
    Posted Jan 19, 2014 12:42 PM
    The advanced troubleshooting course says 239 but an older AOS user guide says 224.
  • 4.  RE: ADP multicast address
    Posted Jan 19, 2014 01:08 PM
    I would look at the most up-to-date AOS guide, because over time, there are corrections, of course.  http://www.arubanetworks.com/techdocs/ArubaOS_63_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/AP_Config/Deploying_APs.htm
  • 5.  RE: ADP multicast address
    Posted Jan 19, 2014 02:54 PM
    From a support point of view I could encounter controllers running any code version - Is the correct address the 224 or 239 or have they both been in use over different code versions?
  • 6.  RE: ADP multicast address
    Posted Jan 19, 2014 04:13 PM
    It is 239.0.82.11 currently.  I cannot speak to the history.
  • 7.  RE: ADP multicast address
    Posted Jan 19, 2014 04:24 PM
    It is 239.0.82.11 the correct address:
    Here's a capture from the latest 6.3.x.x code
