Advertise QBSS Load Information Element in Beacon.
  • 1.  Advertise QBSS Load Information Element in Beacon.
    Posted Feb 19, 2013 12:48 PM
    Ever wanted to know how many clients are associated to a Basic Service Set without looking in the controller? If yes then enable QBSS Load IE.
    Go to your SSID profile and click Advanced.
    Scroll down until you see Advertise QBSS Load IE
    Click it then apply.
    Now fire up your packet capture utility and check it out.
    Let me know if you have used this in the field and for what purpose.
  • 2.  RE: Advertise QBSS Load Information Element in Beacon.
    Posted Feb 19, 2013 01:01 PM
    That would be "A" for Awesome, Srynearson!
  • 3.  RE: Advertise QBSS Load Information Element in Beacon.
    Posted Mar 12, 2013 07:27 AM
    Nice post Sean :), I have used QBSS in a Cisco Infra for a Voice Client  Troubleshoot scenario where ASCOM phones were doing some agressing Roam...Eventually it  narrowed down to be a load issue in one of the AP's.
  • 4.  RE: Advertise QBSS Load Information Element in Beacon.
    MVP
    Posted Aug 02, 2013 08:49 AM
    Dragging up an old topic here, but would there be any reason NOT to enable this?
    And is it still usefull with arm's client-match?
    Would having both enabled be good/better/not advicable?
  • 5.  RE: Advertise QBSS Load Information Element in Beacon.
    Posted Aug 02, 2013 08:57 AM
    The reason why it was added because Cisco phones leverage that parameter and in a multivendor environment, those phones would prefer access points that have that element enabled. It is much less useful in a uniform environment.
    I would say, you never know how a client responds to that check box, so if you do not have Cisco phones in a multivendor environment, do not enable it.
  • 6.  RE: Advertise QBSS Load Information Element in Beacon.
    Posted Aug 02, 2013 09:48 AM
    It again depends on whether Load based CAC is used or BandWidth based CAC is configured on, if it is load based CAC, then enabling QBSS Load IE will help in a Mixed Client Environment.
