Was busy setting up clearpass. Edit the print template and the from there cant access anything on the guest pass side. Even the deafult guest_index.php doesnt work anymore. Did the so called cluster restore command via CLI but doing the same. Anyone experienced this issue and perhaps know how to properly roll back.
I do get redirected to the login page when i need to authenticate first. Once i submit nothing happends. It goes to the guest_index.php in the URL but its completely blank, cant access any other php pages on the guest side either.
Does the same.
Good morning.
I have got the same issue: the page appears blank?
Any update?
Thanks.
Regards.
Andrea
Many thanks Joseph.
This is a bug. I need to update to version 6.6.
