after configure SLB ,the show result is conflict.
  • 1.  after configure SLB ,the show result is conflict.
    Posted Dec 08, 2014 01:18 AM
    when I use show ap active ,it shows only 2 2.4g client ,picture "slb1"
    when I use show ap association ,it shows 4 2.4g client ,picture "slb2"
  • 2.  RE: after configure SLB ,the show result is conflict.
    Posted Dec 08, 2014 03:56 AM
    Colin Wang,
    What version of ArubaOS is this?
  • 3.  RE: after configure SLB ,the show result is conflict.
    Posted Dec 08, 2014 04:10 AM
    Version 6.3.1.7
  • 4.  RE: after configure SLB ,the show result is conflict.
    Posted Dec 08, 2014 09:22 AM
    Hi Friend,
    These are two different out puts,
    1. show AP active will show howmany APs terminated on the controller currently and how many clients associated on a perticular radio.
    2. show AP association will show APs along with BSSIDs and also associated clients. the output which you have pointed is about the ARM band stearing,
    Total num of 5G capable clients: means howmany 5GHz clients requested for only 5GHz
    Total num of 5G capable clients in 2.4G band: means howmay 5GHz clients requested for 5 GHz and steared to 2.4 GHz
    Total num of 5G capable clients in 5G bandmeans howmany 5GHz clients requested and associated in 5GHz band
    Total num of 2.4G only clients: means howmany clients requested only for 2.4 GHz band
    The above numbers will dynamically changes asper the client behaviour and ARM band stearing.
    therefore we should not consider the number shown alongwith the above parameters as the total number of clients.
    Hope got the clarity, if not please feel free to ask any further help.
    Cheers,
    Venu Puduchery
  • 5.  RE: after configure SLB ,the show result is conflict.
    Posted Dec 08, 2014 09:13 PM
    sound good. thanks.
