After many retries, 802.1x authentication is disabled in profile
  • 1.  After many retries, 802.1x authentication is disabled in profile
    Posted Apr 03, 2012 11:04 AM
    My Aruba OS 6.1.2.5
    Problem: an ipod touch user tried many times to authenticate PEAP 802.1x  and now probably lock out by the controller (see log: 802.1x authentication is disabled in profile).  And today after more than 12 hours, EAPOL is still dropping
    Questions:
    1. What is "802.1x authentication is disabled in profile"?
    2. Anyway to re-enable authentication?
    Thanks.
    (WC02) #show log all | include 00:26:b0:2f:aa:79
    Apr  2 16:38:02  authmgr[1641]: <132053> <ERRS> |authmgr|  Dropping the radius packet for Station 00:26:b0:2f:aa:79 00:0b:86:50:f9:e1 doing 802.1x
    Apr  2 16:38:25  authmgr[1641]: <132053> <ERRS> |authmgr|  Dropping the radius packet for Station 00:26:b0:2f:aa:79 00:0b:86:50:f9:e1 doing 802.1x
    Apr  2 16:38:25  authmgr[1641]: <132197> <ERRS> |authmgr|  Maximum number of retries was attempted for station ngutri 00:26:b0:2f:aa:79 00:0b:86:50:f9:e1, deauthenticating the station
    Apr  2 16:43:51  authmgr[1641]: <132030> <ERRS> |authmgr|  Dropping EAPOL packet sent by Station 00:26:b0:2f:aa:79 00:0b:86:50:f9:e1
    Apr  2 16:47:05  authmgr[1641]: <132023> <ERRS> |authmgr|  802.1x authentication is disabled in profile  Station 00:26:b0:2f:aa:79 00:0b:86:50:f9:e0
    Apr  2 16:47:05  authmgr[1641]: <132030> <ERRS> |authmgr|  Dropping EAPOL packet sent by Station 00:26:b0:2f:aa:79 00:0b:86:50:f9:e0
    Apr  3 08:25:13  authmgr[1641]: <132030> <ERRS> |authmgr|  Dropping EAPOL packet sent by Station 00:26:b0:2f:aa:79 00:0b:86:50:f9:e1
    (WC02) #
  • 2.  RE: After many retries, 802.1x authentication is disabled in profile
    Posted Apr 11, 2012 01:15 PM
    Would it be possible for you to share some config,
    'show aaa profile xyz'
    'show aaa auth dot1x abc'
  • 3.  RE: After many retries, 802.1x authentication is disabled in profile
    Posted Apr 16, 2012 09:13 AM
    Here are the profiles:
    Notes: for troubleshooting this problem, I make all roles in these profiles (COMPUTER-ROLE, PDA-ROLE, and EMPLOYEE-ROLE) "allow all"
    (WC01) #show aaa authentication dot1x DOT1X-PF
    802.1X Authentication Profile "DOT1X-PF"
    Parameter                                                  Value
    Max authentication failures                                0
    Enforce Machine Authentication                             Disabled
    Machine Authentication: Default Machine Role               COMPUTER-ROLE
    Machine Authentication Cache Timeout                       12 hr(s)
    Blacklist on Machine Authentication Failure                Disabled
    Machine Authentication: Default User Role                  PDA-ROLE
    Interval between Identity Requests                         30 sec
    Quiet Period after Failed Authentication                   30 sec
    Reauthentication Interval                                  86400 sec
    Use Server provided Reauthentication Interval              Disabled
    Multicast Key Rotation Time Interval                       1800 sec
    Unicast Key Rotation Time Interval                         900 sec
    Authentication Server Retry Interval                       30 sec
    Authentication Server Retry Count                          2
    Framed MTU                                                 1100 bytes
    Number of times ID-Requests are retried                    3
    Maximum Number of Reauthentication Attempts                3
    Maximum number of times Held State can be bypassed         0
    Dynamic WEP Key Message Retry Count                        1
    Dynamic WEP Key Size                                       128 bits
    Interval between WPA/WPA2 Key Messages                     1000 msec
    Delay between EAP-Success and WPA2 Unicast Key Exchange    0 msec
    Delay between WPA/WPA2 Unicast Key and Group Key Exchange  0 msec
    Time interval after which the PMKSA will be deleted        8 hr(s)
    WPA/WPA2 Key Message Retry Count                           3
    Multicast Key Rotation                                     Disabled
    Unicast Key Rotation                                       Disabled
    Reauthentication                                           Enabled
    Opportunistic Key Caching                                  Enabled
    Validate PMKID                                             Disabled
    Use Session Key                                            Disabled
    Use Static Key                                             Disabled
    xSec MTU                                                   1300 bytes
    Termination                                                Disabled
    Termination EAP-Type                                       N/A
    Termination Inner EAP-Type                                 N/A
    Token Caching                                              Disabled
    Token Caching Period                                       24 hr(s)
    CA-Certificate                                             N/A
    Server-Certificate                                         N/A
    TLS Guest Access                                           Disabled
    TLS Guest Role                                             guest
    Ignore EAPOL-START after authentication                    Disabled
    Handle EAPOL-Logoff                                        Disabled
    Ignore EAP ID during negotiation.                          Disabled
    WPA-Fast-Handover                                          Disabled
    Disable rekey and reauthentication for clients on call     Disabled
    Check certificate common name against AAA server           Enabled
    (WC01) #show aaa profile  AAA-PF
    AAA Profile "AAA-PF"
    Parameter                           Value
    Initial role                        logon
    MAC Authentication Profile          N/A
    MAC Authentication Default Role     COMPUTER-ROLE
    MAC Authentication Server Group     N/A
    802.1X Authentication Profile       DOT1X-PF
    802.1X Authentication Default Role  EMPLOYEE-ROLE
    802.1X Authentication Server Group  BT-RADIUS
    L2 Authentication Fail Through      Disabled
    RADIUS Accounting Server Group      N/A
    RADIUS Interim Accounting           Disabled
    XML API server                      N/A
    RFC 3576 server                     N/A
    User derivation rules               N/A
    Wired to Wireless Roaming           Enabled
    SIP authentication role             N/A
    Device Type Classification          Enabled
    Enforce DHCP                        Enabled
  • 4.  RE: After many retries, 802.1x authentication is disabled in profile
    Posted Nov 06, 2012 02:52 AM
    did you ever figure this one out?
  • 5.  RE: After many retries, 802.1x authentication is disabled in profile
    Posted Mar 19, 2013 06:21 PM
    I see this is an old thread, but posting response anyway. Note the BSSID's recorded in the log messages. After failing dot1x on f9:e1, client is flipping over to a different SSID (f9:e0).
    Best guess is that this second SSID is OPEN, no dot1x profile attached. So controller ignores EAPOL on that SSID and posts this message.
