Wired Intelligent Edge
After reboot switch uses backup tunneled node IP
  • 1.  After reboot switch uses backup tunneled node IP
    Posted May 23, 2018 04:39 AM
    Dear Community
    I have a setup with 2930F switches and AOS 8.2.1 WLC (no clustering) with MM. I use PUTN and downloadable user-roles.
    Everything works fine but whenever a switch is rebooted it uses the backup-controller to build the tunnel.
    Does somebody know why? From my understandig the switch should use the primary controller-ip whenever it's reachable.
    tunneled-node-server
     controller-ip 10.50.10.254
     backup-controller-ip 10.40.10.254
     keepalive interval 1
     mode role-based
     enable
    Best Regards
    Marc
  • 2.  RE: After reboot switch uses backup tunneled node IP
    Posted May 23, 2018 02:12 PM
    Marc,
    Can you please also provide your AOS controller configs?  I agree, the backup connection after a reboot should not happen.  Have you adjusted the keepalive interval to 8 seconds (default) or greater?
    Rob
  • 3.  RE: After reboot switch uses backup tunneled node IP
    Posted May 23, 2018 07:09 PM
    Hi Marc,
    I'm seeing the same behavior in my lab setup.  It appears that the "operational roles" switch when the switch is rebooted:
    Dyn-Seg-Demo(tunneled-node-server)# show tunneled-node-server state
    Local Master Server (LMS) State
    LMS Type IP Address State Capability Role
    Primary : 10.1.1.31 Complete Per User Operational Primary
    Secondary : 10.1.1.32 Complete Per User Operational Secondary
    Switch Anchor Controller (SAC) State
    IP Address Mac Address State
    SAC : 10.1.1.31 000c29-25137b Registered
    User Anchor Controller (UAC) : 10.1.1.31
    User Port VLAN State Bucket ID
    Dyn-Seg-Demo(config)# show tunneled-node-server state
    Primary : 10.1.1.31 Complete Per User Operational Secondary
    Secondary : 10.1.1.32 Complete Per User Operational Primary
    SAC : 10.1.1.32 000c29-071ba0 Registered
    User Anchor Controller (UAC) : 10.1.1.32
    I will get this in to R&D to be fixed.  The switch should reach out to the primary controller after a reboot first.
    A workaround to reset is to disable the tunneled-node-server command:
    Dyn-Seg-Demo(tunneled-node-server)# no enable
    Dyn-Seg-Demo(tunneled-node-server)# enable
    Justin
    JUSTIN NOONAN
    TECHNICAL MARKETING ENGINEER – ARUBA WIRED INTELLIGENT EDGE
    O: +1 916 540 1748   |   justin.noonan@hpe.com
    8000 FOOTHILLS BLVD  |  ROSEVILLE, CA 95747 USA
  • 4.  RE: After reboot switch uses backup tunneled node IP
    Posted May 28, 2018 04:57 AM
    Hi Justin
    Thank you for your feedback. Allright, can you already say when this is fixed or by what version?
    Best Regards
    Marc
  • 5.  RE: After reboot switch uses backup tunneled node IP
    Posted May 31, 2018 06:57 PM
    Hi Marc,
    R&D is still investigating and prioritizing as to when it would be implemented into a future software update.
    Justin
  • 6.  RE: After reboot switch uses backup tunneled node IP
    Posted Jun 25, 2018 08:07 AM
    Hi Justin
    Do you have any news on this? We have some customer requests.
    Best Regards
    Marc
  • 7.  RE: After reboot switch uses backup tunneled node IP
    Posted Jun 26, 2018 12:30 PM
    Hi Marc,
    We have an enhancement request that has been raised for tracking this.  No current timeline yet.
    Justin
