Aftter installin ClearPass Cumulative Patch 1 for 6.3.0 webui doesn't work properly,
  • 1.  Aftter installin ClearPass Cumulative Patch 1 for 6.3.0 webui doesn't work properly,
    Posted Mar 27, 2014 10:33 AM
    I have two CPPM (ClearPass Policy Manager ) in HA.
    This morning i have installed the ClearPass Cumulative Patch 1 for 6.3.0 that i have found in "Software Update" tab of the web-ui.
    I have installed it only on member that was in down state.
    The installing is completed correctly, without errors.
    I have rebooted the CPPM and after the reboot the webui of it cannot be reached.
    If i try to connect, on the browser appear the following message:
    " ClearPass Policy Manager™ could not find the page you requested. Redirecting in 5 seconds... "
    and continue to redirect me on the same page.
    I have tried to connect with different browser and with different version of these.
    and i have tried to reboot the CPPM, but without success.
    Have you any ideas?
    Thanks in advance.
  • 2.  RE: Aftter installin ClearPass Cumulative Patch 1 for 6.3.0 webui doesn't work properly,
    Posted Mar 27, 2014 10:34 AM
    Wait about 10 minutes and then do a service restart all.
    It should fix itself.
  • 3.  RE: Aftter installin ClearPass Cumulative Patch 1 for 6.3.0 webui doesn't work properly,
    Posted Mar 27, 2014 10:39 AM
    HI,
    Thank you.
    I have tried with "service restart all"  but unfortunelly the situation is the same.
  • 4.  RE: Aftter installin ClearPass Cumulative Patch 1 for 6.3.0 webui doesn't work properly,
    Posted Mar 27, 2014 10:40 AM
    I would open a TAC case then. Most of these cases have resolved themselves with a service restart.
  • 5.  RE: Aftter installin ClearPass Cumulative Patch 1 for 6.3.0 webui doesn't work properly,
    Posted Mar 31, 2014 04:40 AM
    i have opened a case with TAC.
    I will update you when this issue is solved.
