aiClientTxRate and aiClientRxRate OID returns too high Values
  • 1.  aiClientTxRate and aiClientRxRate OID returns too high Values
    Posted Sep 12, 2018 08:50 AM
    Hi all,
    I'm trying to monitorize wireless client rates via SNMP using the aiClientTxRate and  aiClientRxRate OIDs included in the AI-AP-MIB.
    The obtained results are not the expected. The returned values are too high and the summarized values are around 6 Gb for each of the WLANs.
    I've seen the OID aiClientRxDataBytes in the same mib, and I think the returned values are more accurate. The problem is this value is a counter, so it complicates the processing of the data by our monitoring system.
    Have anyone experienced these behaviour? Can anyone confirm this or tell me if I'm wrong?
    Victor.
  • 2.  RE: aiClientTxRate and aiClientRxRate OID returns too high Values
    Posted Sep 12, 2018 08:57 AM
    Do you have any examples?
  • 3.  RE: aiClientTxRate and aiClientRxRate OID returns too high Values
    Posted Sep 12, 2018 09:43 AM
    Sure! I attach a file with the snmpwalk query and response.
    The value returned is supposed to be Mbps. I can assure that the wireless clients are not consuming those bandwidths.
    Thanks in advance!
    Attachment(s)
    txt
    aiClientRxRate_example.txt   57 KB 1 version
  • 4.  RE: aiClientTxRate and aiClientRxRate OID returns too high Values
    Posted Sep 12, 2018 09:46 AM
    Those values are transmit rates, not data transmitted.  The parallel would be the output from the "show ap debug client-table ap-name <name of ap>"
  • 5.  RE: aiClientTxRate and aiClientRxRate OID returns too high Values
    Posted Sep 12, 2018 09:51 AM
    Got it. I'll use aiClientTxDataBytes instead to obtain the value that I need.
    thanks!
