Network Management
Air Recorder download
This thread has been viewed 50 times
  • 1.  Air Recorder download
    Posted Sep 09, 2019 09:27 AM
    Is air recorder still supported by Aruba? Also, what are Aruba's future plans about it?
    Also I need a copy of it, which I can't seem to find on https://support.arubanetworks.com/ToolsResources/tabid/76/Default.aspx
  • 2.  RE: Air Recorder download
    Posted Sep 10, 2019 04:41 AM
    AirRecorder 1.5.8 (May 2019) is downloadable in that location after you logged in to the support website. As soon as you are logged in, the folder shows up.
    You will need to have a valid account on the support website.
  • 3.  RE: Air Recorder download
    Posted Sep 10, 2019 04:48 AM
    Thanks!
    Do you know anything about Aruba's future plans about network automation/AirRecorder?
  • 4.  RE: Air Recorder download
    Posted Sep 10, 2019 04:56 AM
    I have not heard any change of direction in AirRecorder. That tool is developed and maintained by the Aruba support teams and used by those teams.
    On the network automation side, it may be good to contact your local Aruba team as it is a broad topic and touches all of the Aruba products.
