Air Slice AOS 8.7
  • 1.  Air Slice AOS 8.7
    Posted Jun 26, 2020 10:51 AM
    Testing out Air Slice features in AOS 8.7 with AP-535's.
    "Air Slice, designed for 11ax APs optimizes user experience and assures QoS to enterprise applications. Air Slice combines AppRF and UCC for classifying applications and it also supports custom flow definitions."
    When I go to Dashboard > Overview > Clients the traffic analysis doesn't show anything for any of the clients I look at. DPI is enabled on the FW.
    If I look at Dashboard > Traffic Analysis I see all kinds of applications.
    Not sure what else I need to enable to get the stats (Latency/Jitter) to show up in the GUI when monitoring a client?
    It's showing in the CLI:
    airslice-profile "default"
    airslice-app-monitoring
    airslice-policy
    I also enabled both ap-stats and ap-app-stats in the mgmt-server profiles.
    Not sure if this is related or not, but I have ap health checks enabled and can see stats in the CLI.
    Thanks for any suggestions.
  • 2.  RE: Air Slice AOS 8.7
    Posted Jun 26, 2020 04:37 PM
    Is that Airslice profile attached to the ap-group that you want to be monitoring?
  • 3.  RE: Air Slice AOS 8.7
    Posted Jun 26, 2020 07:22 PM
    Yes, it is.  I'm just using the default AirSlice profile.
  • 4.  RE: Air Slice AOS 8.7
    Posted Jun 26, 2020 09:12 PM
    Yes, but look at ap-group and see if the profile is applied.  You are looking at all profiles.
  • 5.  RE: Air Slice AOS 8.7
    Posted Jun 29, 2020 09:58 AM
    The default air slice profile is applied to the ENS-Office AP Group.
    At this point, I'm going to put it on the back burner and wait for a. .1 release of 8.7.0.  The required steps for configuring it aren't that difficult unless there are undocumented commands that didn't make it into the 8.7.0 UG.  Thanks for your help.
