not a huge issue but after upgrading to 8.2.2.1 you can see from the attached image that user counts are not working as expected. ever 30 minutes 400 - 500 devices apear to drop off. (clients dont actually disconnect) anyone seen this or just me? the same is true for the usuage graph. seems to have gone wonky.
no APs go down during this time. airwave is monitoring 14 IAP clusters. from within groups you can see the client count drop off in the clusters but clients arent affected. AMON is on and prefered over snmp
Local lan within their own vlan
You should open a TAC case to determine if there is a problem with your local lan, or the current version of Airwave. It is hard to determine what could be wrong here...
