Community Feedback
How is the community doing? Do you have any questions or feedback related for the Airheads Community team? This is the place to let us know.
Airgroup Config 8.4 MM
  • 1.  Airgroup Config 8.4 MM
    Posted Mar 11, 2019 01:34 PM
    I'm going through the ACMPv8 Airgroup config and I'm noticing quite a bit has moved around in 8.4.0 with the MM.
    Ex:  Navigate to MM->Config->Services->Airgroup
    Expand General
    Select the following
    MDNS
    DLNA
    Yep that doesnt even exist anymore.
  • 2.  RE: Airgroup Config 8.4 MM
    Posted Mar 12, 2019 08:34 AM
    I spung up a new MM with no redundancy and the AirGroup settings are there. However in my L2 Redundancy MM's its not.
    Yes I've clicked the individual MM and the MM group settings.
    Yes I've checked that the AirGroup service is installed and running.
    Yes I've rebooted the MMs.
    I'm going to rebuild the MMs and see what broke.
  • 3.  RE: Airgroup Config 8.4 MM
    Posted Aug 21, 2019 10:02 AM
    Was there a resolution for this issue? I'm trying to enable Airgroup, and only can enable at the controller level within the MM.
