AirGroup Fails to Enable
  • 1.  AirGroup Fails to Enable
    Posted Nov 16, 2012 12:22 PM
    I am working with a customer who has a two controller deployment.   We have 6.1.3.4-AirGroup installed.   I can turn on AirGroup on the local controller successfully, but not the master.   I have attmpted repeatedly to run airgroup enable; but it continues to show disabled when running show airgroup status; any thoughts?   I am going to try and reboot the controller, but looking for an alternative if there may be one.
    (aruba-master) (config) #airgroup enable
    (aruba-master) (config) #exit
    (aruba-master) #show airgroup status
    AirGroup Feature
    Status
    Disabled
    AirGroup Enforce Registration
    Status
    Disabled
    AirGroup Service Information
    Service   Status
    airplay   Enabled
    airprint  Enabled
    allowall  Enabled
  • 2.  RE: AirGroup Fails to Enable
    Posted Nov 16, 2012 12:41 PM
    after a reboot; i was able to enable it.
  • 3.  RE: AirGroup Fails to Enable
    Posted Dec 19, 2012 09:58 AM
    I'm running the same code myself - and one odd thing that I've found with AirGroup is that without a 'write mem' AirGroup shows disabled after what seems like a couple minutes.
    I have to enabled it again and write mem for it to stay on.
  • 4.  RE: AirGroup Fails to Enable
    Posted Dec 20, 2012 02:18 PM
    airgroup doesnt really work well in a master / local deployment though.
  • 5.  RE: AirGroup Fails to Enable
    Posted Dec 20, 2012 04:21 PM
    It seems to work just fine for me so far.  I do have overlapping VLANs between my master and local controllers - so I only have AirGroup turned on on one controller.
  • 6.  RE: AirGroup Fails to Enable
    Posted Dec 24, 2012 06:10 AM
    yeah if you stick to that approach it would be fine.
  • 7.  RE: AirGroup Fails to Enable
    Posted Sep 11, 2013 11:12 AM
    we have OS v.6.2.1.3 and there is no mention of "airgroup" here.
    Controller is 3400 and I'd like to be able to use this feature. As seen from this post it was available in previous OS release, but omitted from the latest.
    Any ideas what happened to airgroup feature in latest OS release?
  • 8.  RE: AirGroup Fails to Enable
    Posted Sep 11, 2013 11:53 AM
    AirGroup was a technology release in 6.1.x and not a part of the main release track. The latest code that supports AirGroup is 6.3.x
