I am looking for a solution to allow an Apple TV to connect to a Guest Network that has a Captive Portal. I beleive this would be done by registering the device in to the Guest Device reposirory as normal. We would then re-configure the MAC Authentication service to query the Guest Device Repository. This would then allow the AppleTV to connect without hitting the Portal. This was discussed in the following thread however it does not seem to work for me. The MAC Auth fails.
http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/Controller-Captive-Portal-ClearPass-AppleTv-Question/td-p/155312
Any ideas?
Image attached...
For some reason, it says it is using Local:Localhost as an authentication source. Not sure why. It is not conmfigured on the service.
That was it!
How did you determine it was the Policy?
