last person joined: 11 hours ago
Airgroup Usage Clarification & Questions
  • 1.  Airgroup Usage Clarification & Questions
    Posted Dec 05, 2022 03:07 PM
    In my lab environment I enabled Airgroup and it broke printing when the device and the printer were in the same vlan.  The issue was fixed by disabling Airgroup.  I already had broadcast filtering disabled.
    I found a post, which I can't find now, that stated Airgroup is only used in a Layer 3 environment.  It acts as a Bonjour gateway / mDNS proxy.  The post stated that when in a Layer 2 environment Airgroup breaks Bonjour/mDNS.  That's pretty much what I saw.
    This seems like Airgroup is a little broken.  My lab has clients that print within the same vlan as well as the printer and clients in a separate vlan that also need to print.  I also have seen some of my clients setup the same way.  Not ideal and definitely not a best practice setup, I agree, but it's something that I come across and don't always have the ability to fix.
    It seems the best course is to disable Airgroup then perform Bonjour Gateway/mDNS proxy at whatever device is performing routing functions.  In my lab, it would be a Palo Alto firewall or a Fortinet firewall.
    Is what I read correct and is this the only way around the issue?
  • 2.  RE: Airgroup Usage Clarification & Questions
    Posted Dec 06, 2022 09:07 AM
    Please check the AirGroup Deployment Guide for more info.
    AirGroup includes a Bonjour/mDNS/DLNA proxy and can provide filtering on it. The reason to put this inside your Aruba would be that you can still block/contain the multicast traffic which may kill your WiFi preformance. AirGroup will perfectly work for L2 or L3 (routed) clients, as long as your AP/controller has visibility in each of the VLANs that are used for your mDNS/DLNA servers.
