airgroup with ldap authentication
  • 1.  airgroup with ldap authentication
    Posted Jul 26, 2013 12:50 PM
    Is there any good example document available for airgroup in AD environment?  Looking to control airplay (reflection) for sepecific users.  What is best practice around this? Is it better to create seperate SSID or can be work with existing 802.1X SSID?
    Thank you
  • 2.  RE: airgroup with ldap authentication
    Posted Jul 26, 2013 12:59 PM
    Are you using ClearPass?
  • 3.  RE: airgroup with ldap authentication
    Posted Jul 26, 2013 01:00 PM
    I am using clearpass.
  • 4.  RE: airgroup with ldap authentication
    Posted Jul 26, 2013 01:02 PM
    Please look at Chapter 5 in this document which talks about using LDAP with ClearPass for AirGroup.
    Attachment(s)
    pdf
    ArubaAirGroup-6136-DG.pdf   1.10 MB 1 version
  • 5.  RE: airgroup with ldap authentication
    Posted Jul 26, 2013 01:05 PM
    I think i am just confuse about forcing registration for airgroup device. Most employees login with 8021x auth.  and device on seperate TLS SSID. If i force airgroup registrations, so they will get prompt for airgroup specific credentials?
  • 6.  RE: airgroup with ldap authentication
    Posted Jul 26, 2013 01:07 PM
    The AirGroup registration page in Guest can be configured to use LDAP through a RADIUS request or Single Sign On (SSO/SAML). They will use their normal credentials.
  • 7.  RE: airgroup with ldap authentication
    Posted Jul 26, 2013 01:09 PM
    cool. I am going to upgrade controller to 6.3.0 tonight and going to test out.
    Thank you
