Hi
Running Arubna Instant 8.9.0 and cppm 6.10.2
Is ther anything special you need to do to get airgroups running over multiple networks
Have a cluster of 303H aps supporting 2 vlan s
cotw - wpa3-enterprise network for all our mac/iphones runnig eap-tls using clerpas as a CA/onbaording device
mydevices - wpa2-psk network devices need registered on clearpass guest performs macauth and use downloadable user roles to aply an "allow all" acl set to devices. All headless deviices live on the mydevies ssid
ISC dhcp/dns server provides all the background stuff.
2930 switch acts a a router between the vlans
Everything works fine apart from airgroups . All amazon alexa stuff works, can talk to my printer on mydevices but cannot see Airgroup/print/play devies on the cotw network at all .
Clearpass guest device registrations are set up as "shared" devices so anyone should be able to see them
Attached files are
1) Instant airgroup config
2). Clearpass mydevices authentication of epson printer
3). Clearpass airgroup service relating to epson printer
worked just fine on a controller based setup
Cant help feeling I've got somethnig missing
A
Alex Sharaz
