AirMagnet Planner Power Settings
  • 1.  AirMagnet Planner Power Settings
    Posted Sep 16, 2014 12:07 PM
    What power settings should be used in AirMagnet Planner for the Aruba Access Points?
  • 2.  RE: AirMagnet Planner Power Settings
    Posted Sep 16, 2014 04:39 PM
    Hi Ross,
    Don't have it in front of me, but in case it's transmit power in dBm, perhaps you can take a look at the AP line up matrix on the Aruba websitw ( http://www.arubanetworks.com/pdf/products/MAT_AP.pdf ) which references that for each AP.
