Cloud Managed Networks
AIRMATCH AOS10 in Aruba Central
  • 1.  AIRMATCH AOS10 in Aruba Central
    Posted Dec 07, 2022 09:51 AM
    Hi guys,
    We have noted that on AOS10 the configuration for Air MAtch is placed under the GLOBAL level on Aruba Central. But, what if I want to set a different air match configuration per GROUP level ? is that possible? Or air match is only a global configuraton that will apply to all my groups?
  • 2.  RE: AIRMATCH AOS10 in Aruba Central
    Posted Dec 07, 2022 08:32 PM
    airmatch RF calculations are based on the physical locations of APs which means that even different sites in the same group are calculated separately.
    Each group configuration can have its own radio profile (power and channel limitations) assigned to an AP  and airmatch would take that into account.
    https://www.arubanetworks.com/techdocs/AOS10_3_OLH/Content/aos10x/monitoring/radio-resource-mgmt.htm
