Cloud Managed Networks
Forum to discuss all things Aruba Central and UXI Network Management, this includes Aruba Central managed networks, Central configuration, best practices, Central APIs, Cloud Guest, AIOps, Presence Analytics and Other Central Applications
AIRMATCH AOS10 in Aruba Central
This thread has been viewed 21 times
  • 1.  AIRMATCH AOS10 in Aruba Central
    Posted Dec 07, 2022 09:51 AM
    Hi guys,
    We have noted that on AOS10 the configuration for Air MAtch is placed under the GLOBAL level on Aruba Central. But, what if I want to set a different air match configuration per GROUP level ? is that possible? Or air match is only a global configuraton that will apply to all my groups?
  • 2.  RE: AIRMATCH AOS10 in Aruba Central
    Posted Jan 11, 2023 03:26 PM
    Why would you want to limit AirMatch to a particular Group?
    Suppose you have two groups in a site. If you were to enable AirMatch in one group and not the other, then AirMatch would not be able to perform the functions described in the docs, with trusted accuracy and reliability.
    I would sugest this article about AirMatch functionality. Perhaps it can convince you why it is best to use AirMatch accross the entire WLAN
    https://www.arubanetworks.com/techdocs/central/latest/content/aos10x/monitoring/radio-resource-mgmt.htm?Highlight=AirMAtch
    Aruba Customer Success Team
