  • 1.  Airmatch Deployment AOS10
    Posted Jun 21, 2024 01:28 PM
    Hi, we are looking to turn on Airmatch to start using this, however as it's done at Global level have concerns over how it will effect the AP's across all the groups. Ideally we only want to use it on the AOS10 Test AP group, is this possible?
  • 2.  RE: Airmatch Deployment AOS10
    Posted Jun 23, 2024 07:39 PM
    Airmatch only works with AOS10 APs and it is basically the next generation of Aruba radio management.
    check this this detailed info on Airmatch
  • 3.  RE: Airmatch Deployment AOS10
    Posted Jun 24, 2024 04:55 AM
    Excellent thanks, so it will only effect the AOS10 groups and aps and ignore the rest?
  • 4.  RE: Airmatch Deployment AOS10
    Posted Jun 24, 2024 06:18 AM
    yes thats correct
