  • 1.  Airmatch error - couldn't connect to server
    Posted Sep 13, 2022 06:24 PM
    I'm trying to view some airmatch info via cli, and I'm getting the following error:
    Error: couldn't connect to server 127.0.0.1:27017 at src/mongo/shell/mongo.js:147
    I get this trying to run:
    show airmatch optimization
    show airmatch solution ap-name <ap-name>
    ...and other cmds.
    Airmatch should be running, as it appears enabled:
    (conductor) [mynode] # show airmatch profile
    AirMatch profile
    Parameter Value
    schedule Enabled
    deploy-hour 5 AM
    quality-threshold 8 percent
    Couldn't find anything of note in the conductor logs.
    Any ideas on what I could check? Are there processes I could check? Can the airmatch module crash? Thanks for any ideas or direction.
    (Two clustered 7240XM's managed by a pair of clustered MM-VA's, all running 8.10.0.2)
  • 2.  RE: Airmatch error - couldn't connect to server
    Posted Sep 14, 2022 03:17 AM
    Looks like the database (MongoDB) is not running. AirMatch uses that to store data. You could check the mongodb:
    (MM01) *[mynode] #show netstat | include 27017
    u_str  LISTEN     0      0      /tmp/mongodb-27017.sock 173728929                 * 0     users:(("mongod",pid=24012,fd=19))
    tcp    LISTEN     0      0              127.0.0.1:27017                 *:*      users:(("mongod",pid=24012,fd=17))
    tcp    ESTAB      0      0              127.0.0.1:50496         127.0.0.1:27017  users:(("python",pid=6707,fd=3))​
    ... then the line with LISTEN and 127.0.0.1:27017; so third line in this example. Every process can potentially crash, but it's not expected, so it may be good to open a TAC case. This is nothing that an end-user should be aware of, in fact, it's the first time I see that this process is running, never bothered as it just works. You could also just reboot your MCR/MM, and see if the process comes back. You can also restart the mongod process: "(MM01) *[mynode] #process restart mongod"; but if it stopped there is probably a reason that needs to be found to prevent the same happening time after time.
  • 3.  RE: Airmatch error - couldn't connect to server
    Posted Sep 14, 2022 09:37 AM
    Edited by codye Sep 14, 2022 09:37 AM
    Thanks Herman! I'll check what you suggest and possibly open the TAC case. Agreed, it would be nice to know why it crashed.
