AIrplay after updated to OS 6
  • 1.  AIrplay after updated to OS 6
    Posted Oct 24, 2013 02:18 PM
    We recently updated from OS 5 to OS 6. Now airplay no longer appears to work. I cant find any settings for airgroup in the cli or the GUI. Has anyone run into this before?
  • 2.  RE: AIrplay after updated to OS 6
    Posted Oct 24, 2013 02:54 PM
    It should be there under configuration, make sure airplay is turned ON from there.
    some useful commands (cli)
    show airgroup status - check airplay is ON
    Show process monitor statistics - to check mdns is running
    Good Luck
  • 3.  RE: AIrplay after updated to OS 6
    Posted Oct 24, 2013 02:57 PM
    I thought it should be there under advanced. Here is what I have.
  • 4.  RE: AIrplay after updated to OS 6
    Posted Oct 24, 2013 03:04 PM
    could u verify from cli,
  • 5.  RE: AIrplay after updated to OS 6
    Posted Oct 24, 2013 03:30 PM
    Airgroup is not an available option for the show command.
  • 6.  RE: AIrplay after updated to OS 6
    Posted Oct 24, 2013 03:52 PM
    can u try enable airgroup from cli, or may be your software version doesnt support airgroup.
  • 7.  RE: AIrplay after updated to OS 6
    Posted Oct 24, 2013 03:58 PM
    Airgroup isnt an option for enable. Here is the version I am running.
  • 8.  RE: AIrplay after updated to OS 6
    Posted Oct 24, 2013 07:30 PM
    Airgroup is only available in ArubaOS 6.3. and above, or the technology release 6.1.3.6-airgroup (not recommended).  You will not see the airgroup commands outside of those releases.
