Airplay through Airgroup drops after 30 seconds
  • 1.  Airplay through Airgroup drops after 30 seconds
    Posted May 08, 2019 09:52 AM
    Dear,
    We have 2 mobility controllers (active - active):
    When setting up Airgroup for Airplay the connection drops after exactly 30 seconds if the 'user' and 'server' are on a different VLAN. This is reproducible and happens every time.
    If 'user' and 'server' are on the same VLAN, the connection is stable.
    Is there some kind of setting that drops the connection after 30 seconds?
    What could be the issue?
    Thank you!
    Ben
  • 2.  RE: Airplay through Airgroup drops after 30 seconds
    MVP
    Posted May 08, 2019 06:43 PM
    Might be worth checking the following commands:
    show airgroup blocked-queries
    show airgroup blocked-service-id
  • 3.  RE: Airplay through Airgroup drops after 30 seconds
    Posted May 09, 2019 12:59 PM
    I found with the most reason firmware version 8.3.0.6_69128 on my IAP 305's mDNS just fails at the AP.  I was able to verify this by downgrading firmware and it worked prior to the most recent update.
    Any help with this issue is greatly appreciated.
  • 4.  RE: Airplay through Airgroup drops after 30 seconds
    Posted May 09, 2019 02:03 PM
    I should say contact TAC for this.
