Airtime Fairness in AOS 8?
  • 1.  Airtime Fairness in AOS 8?
    Posted May 05, 2022 07:36 AM
    What happened to Airtime Fairness in AOS 8?
    I see a traffic management profile which seems to have the same settings as Airtime Fairness did in AOS 6. But I'm not sure where to even apply the profile. It's not well documented for AOS8. Has it been superseded by another technology?
    Brett V
  • 2.  RE: Airtime Fairness in AOS 8?
    Posted May 05, 2022 07:59 AM
    I think the same as aos6.
    you should enable the preferences.
    then,go to the AP Group,Select the corresponding ap-group and click Profiles, the QOS option appears.
    tan xiaofeng
  • 3.  RE: Airtime Fairness in AOS 8?
    Posted May 05, 2022 08:02 AM
    Look at configuration >AP Groups> Profiles> QOS
  • 4.  RE: Airtime Fairness in AOS 8?
    Posted May 05, 2022 08:15 AM
    Thanks guys,
    But it still doesn't appear for me... Mobility Conductor and Controllers are VMs - version 8.6.0.15. I have all necessary licenses.
    Brett V
  • 5.  RE: Airtime Fairness in AOS 8?
    Posted May 05, 2022 08:17 AM
    OK I found it... just had to scroll further across! Thanks heaps!
    Brett V
