Airware Installation
  • 1.  Airware Installation
    Posted Mar 01, 2012 10:56 AM
    Hello All,
    I want to installed the Airware 7.1.3 on our machine. i have download AMP-7.1.3.iso from support site and burn on CD.
    it's 32-bit ISO.   when i boot the CD this message appear.
    "ISOLINUX: 3.11 2005-09-02 Copyright (C) 1994-2005 H. Peter Aavin:
    cound not find kernel image: linux
    boot:--"
    Please guide how to installed Airware.
  • 2.  RE: Airware Installation
    Posted Mar 01, 2012 11:21 AM
    You may need to re-download the image.  Also, you should get the latest version - 7.4.7.  It's a 64-bit image.  You just mount the ISO and install.  Follow the prompts, fairly easy.
    -Mike
  • 3.  RE: Airware Installation
    Posted Mar 01, 2012 11:30 AM
    Thanks Friend for your response. but i have only 32-bit machine right now. so please help to successfully installation on this machine.
  • 4.  RE: Airware Installation
    Posted Mar 01, 2012 11:57 AM
    You may want to re-download.  Also, there is v7.3.8 for 32Bit systems.
    To see if the file is corrupted, check the md5.  Here is the md5sum for 7.1.3 32bit ISO:
    md5sum = b7abae4a7da7ecd7b9d095a2bfc11842
    Compare it to your copy using a md5 checker.
    -Mike
