Network Management
Airware Web Very Slow
  • 1.  Airware Web Very Slow
    Posted Jun 27, 2018 12:09 PM
    Recently use Airware  Web  Very Slow
    the memory using very hight ,but use top command  process max only use 2x&
  • 2.  RE: Airware Web Very Slow
    Posted Jun 27, 2018 01:14 PM
    Hi
    Did you size the server with the sizing tool for AirWave?
    Did you install more devices into airwave recently?
    Hope it helps
  • 3.  RE: Airware Web Very Slow
    Posted Jun 27, 2018 10:04 PM
    Now i have 62 Device
    The VM Size : 1 Core 2 thread /with 5GB Ram
  • 4.  RE: Airware Web Very Slow
    Posted Jun 28, 2018 10:40 AM
    That's even smaller than the VMs I run in the lab!  Our minimum setup in the lab is the same as the minimum for the OVA image that we provide, which is 4 core, 8 GB RAM, 60 GB disk (if VM, thin provision, and make use of snapshots).  We don't perform any performance tests against smaller setups.
  • 5.  RE: Airware Web Very Slow
    Posted Jun 28, 2018 02:24 PM
    Hi
    Stick to the specs of the 1500 devices airwave even if it is a smaller deployment.
  • 6.  RE: Airware Web Very Slow
  • 7.  RE: Airware Web Very Slow
    Posted Jun 29, 2018 09:53 AM
    That link is to an older spec from 4 years ago.  The product has changed, there's new features that require more processing capabilities.  While you could follow the old sizing guide, it doesn't help much since it doesn't take into consideration the newer features like Traffic Analysis, Clarity Live, updated VisualRF algorithms, etc.
  • 8.  RE: Airware Web Very Slow
    Posted Jun 29, 2018 04:30 PM
    Hi
    As the ASE airwave sizing calculator isn’t available anymore I would stick to the 1500 version from the 8.2.6 server sizing guide.
    https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=29748
