Network Management
Airwave 7.4.8 upgrade to Latest
  • 1.  Airwave 7.4.8 upgrade to Latest
    Posted Feb 11, 2014 09:48 AM
    I am currently running airwave 7.4.8 on a Cent OS 5.5 virtual machine.  I would like to upgrade to the latest version of Airwave.
    To bypass all of the upgrade procedures needed to get to the latest version, would i simply be able to download the 7.7.9 virtual appliance?  Can i backup my current AMP data, bring up the new virtual appliance, and restore that data to the appliance.......essentially bypassing all the upgrade procedures i'd need to to to get to 7.7.9 from what i'm running now?
    -Mike
  • 2.  RE: Airwave 7.4.8 upgrade to Latest
    Posted Feb 11, 2014 12:45 PM
    Mike,
    Be aware that Airwave 7.5 & greater requires a 64-bit CentOS.  I believe the virtual appliance includes the OS & AMP, so you should be able to deploy a new version with ease.
    https://arubanetworkskb.secure.force.com/pkb/articles/FAQ/Multi-step-incremental-upgrade-via-interim-version
    If you're already running a 64-bit VM image, then you can probably just run the start_amp_upgrade script, however you will need to perform an incremental upgrade in order to get to the latest version.
    Unfortunately, the safest (recommended & documented) way is to do the incremental updates as needed; even if you move your data to another server / VM w/ the latest AMP version.  My guess is that there are DB changes that will need to be taken into account as your data is migrated to the newer AMP versions.
    https://arubanetworkskb.secure.force.com/pkb/articles/FAQ/How-do-I-move-my-AMP-data-to-a-new-server
    You can try to circumvent the incremental updates however YMMV.
    Best of luck,
  • 3.  RE: Airwave 7.4.8 upgrade to Latest
    Posted Feb 11, 2014 02:17 PM
    -Mike
    Mike,
    You will not be able to restore an AMP 7.4.8 on a AMP running 7.7.9 as the database schema is different.
    What you need to is the following: (safest and longest way)
    This KB Article best describes what you need to do:
    Since 7.4.8 uses a non 64-bit version of the OS. You cannot also go directly from 7.4.x to 7.7.x
    1. Upgrade to the latest 7.5.x version.
    2. Take a backup
    3. Perform a new ISO VM install of 7.5, this should bring you to 64-bit. CentOS 5.5
    4. Restore the backup
    5. Upgrade to the latest 7.6.x version
    6. Take a backup
    7. Perform a new ISO VM install of 7.6.x, this should bring you to CentOS 6.2 (the supported OS for 7.7.9)
    8. Restore your 7.6.x backup
    9. Upgrade to 7.7.9
    10. Voila.
    Safest and easiest way
    To note: I have had issues going from 7.6.5 to 7.7.6 directly so I decided to go 7.6.5 -> 7.7.2 then to 7.7.8 (when it came out) and I had no issues
