Network Management
Airwave 7.6.2 - ERROR: index "client_historical_ip_client_historical_id_idx" ....
  • 1.  Airwave 7.6.2 - ERROR: index "client_historical_ip_client_historical_id_idx" ....
    Posted Jun 04, 2015 11:02 AM
    yes i know the server is old but we are replacing it with a brand new server.
    In the meantime, we had to perform an emergency reboot and now are seeing this error.
    [root@aws1 scripts]# ./clean_database
    Thu Jun  4 10:52:34 2015:
    expiring old rows failed! ERROR:  index "client_historical_ip_client_historical_id_idx" contains unexpected zero page at block 2454
    HINT:  Please REINDEX it.
    CONTEXT:  SQL statement "DELETE FROM ONLY "public"."client_historical_ip" WHERE $1 OPERATOR(pg_catalog.=) "client_historical_id"": delete from client_historical where disconnect_time < extract(epoch from (to_timestamp(1433429554) - '7 days'::interval))  at /usr/local/airwave/lib/perl/Mercury/Utility/ChangeDB.pm line 838
            Mercury::Utility::ChangeDB::expire_old_rows('client_historical', 'disconnect_time', '7 days') called at /usr/local/airwave/lib/perl/Mercury/Utility/ExpireRows.pm line 112
            Mercury::Utility::ExpireRows::expire_client_historical('Mercury::Utility::ExpireRows') called at ./clean_database line 28
            main::__ANON__() called at /usr/local/airwave/lib/perl/Mercury/Utility.pm line 178
            eval {...} called at /usr/local/airwave/lib/perl/Mercury/Utility.pm line 178
            Mercury::Utility::safe_eval('CODE(0xaca9f0)') called at ./clean_database line 56
    Also, on the WebUI, clicking on an AP sometimes gives us this error page.
    Please dont tell me I need to recompile (root; make)....i can't do that right now...:)
  • 2.  RE: Airwave 7.6.2 - ERROR: index "client_historical_ip_client_historical_id_idx" ....
    Posted Jun 04, 2015 12:30 PM
    and because the ./clean_database script won't run, i cannot backup the server
  • 3.  RE: Airwave 7.6.2 - ERROR: index "client_historical_ip_client_historical_id_idx" ....
    Posted Jun 05, 2015 10:32 AM
  • 4.  RE: Airwave 7.6.2 - ERROR: index "client_historical_ip_client_historical_id_idx" ....
    Posted Jun 05, 2015 12:54 PM
    The reindexing from that article should do the trick, but it has to be done while AMP is disabled or it will take a horribly long time.
  • 5.  RE: Airwave 7.6.2 - ERROR: index "client_historical_ip_client_historical_id_idx" ....
    Posted Jun 05, 2015 01:02 PM
    Ya that's my problem. I need it online because of customer visibility.
    It seems that the client_historical_ip table is foo bared and not accessible even with a select statement.
    I am now worried that DOWNs are not being recorded properly. A new device discovery cannot even be added, I cannot un-ignore certain devices, etc.
    This server sees anywhere from 9,000 to 20,000 clients a day so who knows how large that table is.....
  • 6.  RE: Airwave 7.6.2 - ERROR: index "client_historical_ip_client_historical_id_idx" ....
    Posted Jun 05, 2015 01:06 PM
    The problem will probably prolong if the reindexing doesn't occur.  You might be able to open a support case and get some escalation assistance from a developer.  But any database manipulation should be done during a downtime/maintenance window.
  • 7.  RE: Airwave 7.6.2 - ERROR: index "client_historical_ip_client_historical_id_idx" ....
    Posted Jun 05, 2015 01:15 PM
    Thanks Rob.
    My DBA here says he can do the work but like you mentioned we should disable AMP for it go as fast as possible.
    I have spoken to a TAC guy who has helped me in the past with AMP issues, waiting for his feedback...
