Network Management
Airwave 7.7.11 client count is not showing correctly
  • 1.  Airwave 7.7.11 client count is not showing correctly
    Posted May 30, 2014 07:29 PM
    Airwave 7.7.11, the Client count on top banner is showing incorrectly, it appears to increment instead of reading the conroller count and updating.  Is there a way to purge this client count to let the system reset?  Reboot the Airwave does not seem to fix the issue.
  • 2.  RE: Airwave 7.7.11 client count is not showing correctly
    Posted May 31, 2014 03:59 AM
    If you have "Prefer Amon" on in Airwave, please try turning it off.
    What could also affect that is if you manipulated any of the AAA timers on the Aruba Controller.  They should look like below:
    (192.168.1.3) #show aaa timers
    Global User idle timeout = 300 seconds
    Auth Server dead time = 10 minutes
    Logon user lifetime = 5 minutes
    User Interim stats frequency = 300 seconds
  • 3.  RE: Airwave 7.7.11 client count is not showing correctly
    Posted Jun 02, 2014 01:18 PM
    Hi Colin,
    I was able to turn off the prefer amon on the Airwave, thanks...  where on the controllers can I adjust the "User Interim Frequency"?
    Thanks...
  • 4.  RE: Airwave 7.7.11 client count is not showing correctly
    Posted Jun 02, 2014 01:19 PM
    Hi Colin, I was actually able to find the setting, thanks for your assistance!!
    Cheers,
    David Z
