Network Management
Airwave 7.7.13 and AP205
  • 1.  Airwave 7.7.13 and AP205
    Posted Oct 15, 2014 07:58 PM
    Just upgraded to 7.7.13
    But had some 7210 controllers with AP205 access points.
    Before I upgraded from 7.6.5 the APs showed up as AP50 and did not report correctly because I was told that Aiwave had to go to at least 7.7.12 to recognize the 205's .
    Any way, still can't get airwave to recognize the 205's correctly after deleting them and let airwave discover again.
    Anyone seen this?
    #AP205
    #7210
  • 2.  RE: Airwave 7.7.13 and AP205
    Posted Oct 16, 2014 05:47 AM
    You need to upgrade to Airwave 8.x if possible.  Any access point that is not supported by the specific build of Airwave shows up as an AP50 and a good deal of the data about that AP is probablyu wrong...
    #AP205
  • 3.  RE: Airwave 7.7.13 and AP205
    Posted Oct 16, 2014 07:54 AM
    Thanks cjoseph,
    I do plan to go to 8.0.4 soon.
    The info I received from a tac case said 7.7.12 would be sufficient.
    I guess not unless something else needs to be done.
    #AP205
  • 4.  RE: Airwave 7.7.13 and AP205
    Posted Oct 16, 2014 08:18 AM
    If TAC told you that, that is what you should follow. Let us know how it works.
    #AP205
