Network Management
Airwave 7.7.5 and AOS 6.3.1.0 - mismatch (more like no-match)
  • 1.  Airwave 7.7.5 and AOS 6.3.1.0 - mismatch (more like no-match)
    Posted Nov 06, 2013 03:46 PM
    I upgraded both AMP and AOS in the same week, so I don't really know if it's a 6.3.1.0 bug or a 7.7.5 bug (or just a problem with my installation)
    At this time AMP shows all of my 3400/3600 controllers as mismatched. Specifically all configuration lines added in the upgrade or changed since the upgrade turn up in the Audit page as mismatched.
    Clicking Import on the Audit page makes a lot of syslog entries, and percolates for a while, but none of the proposed changes occur, and the audit page remains resolutely unchanged. Same for Import from the Management page.
    (note the controllers are monitor-only devices, I plan to manage them AFTER I get all of the mismatched resolved)
    Any one else see this sort of issue, or running the same versions and working fine?
    (I am on the wasy to TAC, just checking with the community on route)
  • 2.  RE: Airwave 7.7.5 and AOS 6.3.1.0 - mismatch (more like no-match)
    Posted Nov 06, 2013 05:29 PM
    This is a bug -
    PLEASE UPGRADE to 7.7.6 which was released yesterday
    From ssh@root prompt
    # start_amp_upgrade -v 7.7.6
  • 3.  RE: Airwave 7.7.5 and AOS 6.3.1.0 - mismatch (more like no-match)
    Posted Nov 06, 2013 05:43 PM
    Thanks for the quick response.  I'll let TAC know you said so ;)
    I'll also upgrade tonight -- I'd already downloaded the patch, but was going to wait for TAC to finish collecting whatever data they wanted.
  • 4.  RE: Airwave 7.7.5 and AOS 6.3.1.0 - mismatch (more like no-match)
    Posted Nov 06, 2013 08:43 PM
    That fixed it.
    I'll let TAC know...
  • 5.  RE: Airwave 7.7.5 and AOS 6.3.1.0 - mismatch (more like no-match)
    Posted Nov 06, 2013 09:23 PM
    Sweet!
    Seth R. Fiermonti
    Sr. Systems Engineer
    ACMP, ACCP, ACDX, ACMX
