Network Management
Airwave 7.7.8 VisualRF issue
  • 1.  Airwave 7.7.8 VisualRF issue
    Posted Feb 28, 2014 07:44 AM
    We spun up our Airwave server and it imported all of our controllers and APs.  I began placing the APs on maps of our buildings in VIsualRF but ran into an issue with a few APs.
    Most of our APs show their heatmap after being placed, but some are not.  When I click on the AP and then click the antenna for info it says Status:Error.  I know the ap is functioning because it has clients associated to it.
    I tried removing from the map and readding but it still shows Error.
    Any ideas?
  • 2.  RE: Airwave 7.7.8 VisualRF issue
    Posted Feb 28, 2014 03:37 PM
    I had the same problem here. Solved using 7.7.9.
    Mo
  • 3.  RE: Airwave 7.7.8 VisualRF issue
    Posted Mar 04, 2014 11:48 AM
    The /var/log/visualrf/visualrf.log may show a more verbose reason for the error.  Which AP type are you working with?
  • 4.  RE: Airwave 7.7.8 VisualRF issue
    Posted Mar 04, 2014 11:51 AM
    I am seeing it on 93H's and 135's
    Respectfully,
    Josh Bauman
    Network Infrastructure and Security Administrator
    Maryville University St Louis
    314-529-9512
    [jbqrcode]
  • 5.  RE: Airwave 7.7.8 VisualRF issue
    Posted Mar 04, 2014 12:09 PM
    Interesting, and was there anything additional in the visualrf.log?  Possibly radios assigned to a txpower setting that's not in the library or something similar?
  • 6.  RE: Airwave 7.7.8 VisualRF issue
    Posted Mar 04, 2014 12:14 PM
    I will have to look. I will post what I find.
    Respectfully,
    Josh Bauman
    314-529-9512
    [jbqrcode]
  • 7.  RE: Airwave 7.7.8 VisualRF issue
    Posted Jan 07, 2016 12:02 PM
    Hi Mo;
    Same problem in 8.0.9.
    2016-01-07 17:11:01,148 ERROR Grid Bui[2]  com.airwave.rf.SignalService Device ALS-TBP-Tapete37 radio[1] is invalid, skipping.
  • 8.  RE: Airwave 7.7.8 VisualRF issue
    Posted Jan 08, 2016 03:39 PM
    For those running into this, please be sure to open a support case.  It would definitely help since we're not seeing this issue often in our lab, and it appears to manifest differently for different customers.
  • 9.  RE: Airwave 7.7.8 VisualRF issue
    Posted Dec 22, 2016 07:45 AM
    Thanks.
    We will be opening a case for this issue seen in 8.2.2
