Every time I try to add a map to a campus on Airwave 7.7.9, I get a prompt "Login session timed out". Even if I re-authenticate, I still get this prompt.
I have tried this on Firefox, Chrome and Safari.
Any ideas?
Thanks!
Are you hitting Airwave on its ip address or a fqdn? If it is an fqdn, try it by ip address...
Thanks for the reply. I was using a fqdn. I tried the ip address, but I had the same problem.
I did notice that this problem only happens when I try to set a campus map. I can set a building map with no problem.
Let us check that out. Thanks for bringing it to our attention..
any fix or workarounds for this? im having the same issue.
