Airwave 8
  • 1.  Airwave 8
    Posted Sep 10, 2014 09:56 AM
  • 2.  RE: Airwave 8
    Posted Sep 10, 2014 10:36 PM
    ? what is your question?
  • 3.  RE: Airwave 8
    Posted Sep 11, 2014 09:11 AM
     I installed the Airwave 8in my vmware but I cannot acces via web interface. I tried to stop the service http and restart it althoug without sucess.
    What can I do ?
  • 4.  RE: Airwave 8
    Posted Sep 11, 2014 09:13 AM
    Try running amp_enable at the cli.
  • 5.  RE: Airwave 8
    Posted Sep 11, 2014 09:14 AM
    I did it too.
  • 6.  RE: Airwave 8
    Posted Sep 11, 2014 09:34 AM
    can you post the output of the "wd" command on your cli?
    What are the specs of your VM for AMP 8?
