Network Management
AirWave 8 Server Specs
  • 1.  AirWave 8 Server Specs
    Posted Jul 31, 2014 08:57 PM
    I cann't find documentation showing AW 8 Server Sepcs
    with Airwave 7 There was a atble showing  HW Specs  Versus Number of devices
  • 2.  RE: AirWave 8 Server Specs
  • 3.  RE: AirWave 8 Server Specs
    Posted Jul 31, 2014 09:27 PM
    Here you go
    Its attached on my message, the airwave 8 sizing guide
    Attachment(s)
    pdf
    ServerHardwareGuide.pdf   265 KB 1 version
  • 4.  RE: AirWave 8 Server Specs
    Posted Aug 01, 2014 05:22 AM
    but ath the Guide you attached , still i cann't finad table showing HW Needed Versus numebr of devices ?
  • 5.  RE: AirWave 8 Server Specs
    Posted Aug 01, 2014 05:26 AM
  • 6.  RE: AirWave 8 Server Specs
    Posted Aug 04, 2014 06:26 AM
    Any news ?
  • 7.  RE: AirWave 8 Server Specs
    Posted Aug 04, 2014 08:19 AM
    AMP 8 sizing guide is below, the table is different than what you have but it is a small measuring stick to what you should be looking for. Capture.JPG
    I have an Airwave running 8.0.0 monitoring 532 devices. I was just fine on 7.7.x, after upgrading to 8.0.0,
    I have some performance issues and disk space issues.
    My server is not as performant as the ones indicated above ( we are in the process of upgrading the hardware).
    It  has 16Gb of ram with a a 275Gb HD and an Intel(R) Xeon(R) CPU E31220 @ 3.10GHz 4 Cores 8192 KB cache (3093.100 MHz actual)
    After upgrading a few weeks ago to MAP 8, just now I am starting to run out of diskspace, granted I can tweak historical data retention and run reports, etc..to reduce the disk space usage.
    I see also between 4000-5000 clients a day on this machine.
    I think from this you can judge what kind of server you need. RAM is key and if you want to keep as much data as possible on your server, then get lots of HD space.
  • 8.  RE: AirWave 8 Server Specs
    Posted Aug 05, 2014 05:43 AM
    This Table is 1500 & 4000 devices
    What if we need for 50 / 500 devices ?
  • 9.  RE: AirWave 8 Server Specs
    Posted Aug 05, 2014 07:34 AM
    Then simply adjust your hardware specs. Less HD space, Less RAM, less CPU.
    I wouldn't cheap on the RAM since it is cheap anyway.
  • 10.  RE: AirWave 8 Server Specs
    Posted Aug 05, 2014 12:35 PM
    But Less to How Much ?
    Why Specs is not Clear Ranges like what was with AW 7 ?
  • 11.  RE: AirWave 8 Server Specs
    Posted Aug 05, 2014 12:46 PM
    I cannot answer that unfortunately. Possibly reach out to your local SE or channel manager to help you in this regard.
  • 12.  RE: AirWave 8 Server Specs
    Posted Oct 12, 2014 07:19 PM
    Any News?
  • 13.  RE: AirWave 8 Server Specs
    Posted Jan 10, 2017 09:40 PM
    There is an Airwave server sizing calculator on this URL:
    https://ase.arubanetworks.com/solutions/id/77
    I have used it before to size the server for a customer with quite a large number of APs, but most important, because is a large university campus in the middle of the city the number of neighbour APs (rogue or not) is also very large, this has a big impact on the resources that are required. The sizing calculator is a very good starting point.
    Note the message that this is beta software:
    BETA SOFTWARE
    Please note this is an Aruba Networks beta solution. Sizing is determined by finding the closest engineering tested benchmark and then calculating the percentage difference between the requested device count and the benchmark. Environmental modifier adjustment amounts have not been fully qualified yet; this is a work in progress.
    Max
    This is my personal opinion and in no way represents the posture of HPE Aruba.
