Does Aruba offer any type of classes, tutorial etc. on Airwave 8.0.1? We just upgraded and there are a ton of changes!
If you havent gotten a chance read through the release notes that is the best place to start. The support site has a ton of info on the latest release.
Airwave: Support Site
Hi Donna.
I have been trying to find the proper Airwave 8.0.1 upgrade procedure... Were did you find it?
-Carlos
Hi Carlos,
It's in the release notes how to upgrade but we are having major problems with the VisualRF part of it. It is very different!
Hi Donna,
The AICU course has been updated to 8.0. You can find sessions on the LMS:
http://inter.viewcentral.com/events/cust/catalog.aspx?cid=aruba&pid=1&event_id=6
Is this an online course or do you have to come to Sunny Vale? I'm on the East Coast.
it might not be exactly what you want but you can set visualRF back to flash, that might help for now to a less large change.
