Airwave 8.0.10 and SSH to AP
  • 1.  Airwave 8.0.10 and SSH to AP
    Posted Dec 15, 2015 02:03 PM
    Hi All,
    According to the Airwave 8.0.10 release notes it should be possible to SSH into an AP...
    Remote SSH access to a virtual controller is now supported. To initiate an SSH connection with a virtual
    controller, navigate to Groups > Monitor and click on the IP Address column. A menu will with an SSH link;
    click the link to start the session.
    However I am not seeing this option after the upgrade, does someone have the working ?
    Serge
  • 2.  RE: Airwave 8.0.10 and SSH to AP
    Posted Dec 15, 2015 02:09 PM
    This should be for an instant Ap.... Is that what you are working with?
  • 3.  RE: Airwave 8.0.10 and SSH to AP
    Posted Dec 15, 2015 02:12 PM
    Yes this is for IAP.
  • 4.  RE: Airwave 8.0.10 and SSH to AP
    Posted Dec 16, 2015 07:35 AM
    ssozonoff,
    That feature was not included in this release and should have been removed from the release notes.
    Please stay tuned.
