Network Management
AirWave 8.0.11.1 upgrade failed
  • 1.  AirWave 8.0.11.1 upgrade failed
    Posted Mar 09, 2016 11:06 PM
    so, I tried upgrading, and this is what I got. Any ideas?
    Current Version: RELEASE_8_0_9_2
    [root@spipair01 mercury]# start_amp_upgrade -v 8.0.11.1
    Directory not specified; using /root.
    Upgrade script AMP-8.0.11.1-amp_upgrade was not found in local cache.
    Upgrade package AMP-8.0.11.1-x86_64-cvs.tar.gz was not found in local cache.
    Preparing to connect to Aruba Support Center...
    Enter your Aruba Support Center username: russell.gibbons@horacemann.com
    ######################################################################## 100.0%
    Checking for any patches or modifications to the code
    This process may take a few minutes...
    No outstanding changes were found. Continuing with the upgrade.
    Validating the upgrade package...
    Upgrade package is OK.
    Upgrading AMP to version 8.0.11.1 from version 8.0.9.2...
    Detailed log will be written to /var/log/upgrade/AMP-8.0.11.1-upgrade.log
    STEP 1: Moving old version aside.
    STEP 2: Unpacking upgrade package.
    STEP 3: Checking for compatibility.
    STEP 4: Stopping AMP services.
    STEP 5: Installing upgrade.
    tsdb-server: unrecognized service
    make[3]: Leaving directory `/root/svn/mercury/src/x86_64/rpms/CentOS-6'
    make[2]: *** [perllib] Error 2
    make[2]: Leaving directory `/root/svn/mercury/src'
    make[1]: *** [src_install] Error 2
    make[1]: Leaving directory `/root/svn/mercury'
    make: *** [upgrade] Error 2
    make: Leaving directory `/root/svn/mercury'
    Stopping Pound: [ OK ]
    Stopping httpd: [ OK ]
    Upgrade aborted.
    Russell
  • 2.  RE: AirWave 8.0.11.1 upgrade failed
    Posted Mar 10, 2016 02:06 AM
    Hi Russell,
    Could you please share the complete upgrade log from the path /var/log/upgrade/. Also, opening up a TAC case would be good idea, so that they can take a remote session and further analyze it.
    Vishnu
  • 3.  RE: AirWave 8.0.11.1 upgrade failed
    Posted Mar 10, 2016 02:15 PM
    TAC is your best option here
    #AirheadsMobile
