What version is the AMP showing as? What version did you upgrade from? Were there any issues during the upgrade?
Check for errors in /var/log/upgrade/AMP-8.0.7-upgrade.log
The updating of the database string is the last portion fo the upgrade, it's possible that it quit before that last call.
When it comes to versioning:
1) the home page reflects the database string for amp version
ex:
amp_version = dbc 'select version from seas_config;' = home overview version
2) root; svn info - running this command will show the true running code version
[root@airwave mercury]# svn info
Path: .
Working Copy Root Path: /root/svn/mercury
URL: http://svn.corp.airwave.com/usr/local/svnroot/mercury/tags/RELEASE_8_0_7
Repository Root: http://svn.corp.airwave.com/usr/local/svnroot/mercury
It may be worth opening a support case to make sure that the upgrade completed correctly. If it did and the string is the only thing, it can be updated with a quick database command:
# dbc "update seas_config set version = '8.0.7';"
As for VRF, in the switch from flash to HTML5, the wired closet feature missed the release. It's still on a list of features to be ported over, but if you really want to see that feature, you can toggle back to the old flash -> VisualRF Setup - toggle HTML5 enabled = no. I would say that not many users have commented about it missing, so it'd be a good idea to push an RFE through the ideas portal to bring it back sooner than later.
