Wired Intelligent Edge
Airwave 8.2 and HP 2920 Zerotouch
  • 1.  Airwave 8.2 and HP 2920 Zerotouch
    Posted Nov 14, 2017 12:14 PM
    I am trying to get zero touch working with our 2920's. I currently am on version 16.02.0012 of the switch OS and on Airwave 8.2.5. I have my switch setup in Aruba activate and the switch get's my Airwave address with no issues, but from there the switch will not talk with Airwave. In the logs for the switch I only get the following:
    I 11/14/17 17:06:11 05102 amp-server: AMP server registration started through Primary VLAN.
    I 11/14/17 17:06:11 05103 amp-server: Device registration to AMP server failed.
    The switch can ping the Airwave server so not sure what the issue could be.
    Thank you.
  • 2.  RE: Airwave 8.2 and HP 2920 Zerotouch
    Posted Nov 14, 2017 12:56 PM
    When you have access to the switch's commandline, you should type:
    debug ztp
    debug destination session
    That might give you more info.  You have the right time, which is important.
    If you decide to make changes on the Airwave/Activate side and don't reboot the switch, you might be able to force activation by typing "activate provision force"
  • 3.  RE: Airwave 8.2 and HP 2920 Zerotouch
    Posted Nov 14, 2017 01:14 PM
    enabled the commands and now get this error:
    0000:00:03:18.36 ZTP mairwaveCtrl:Default, Primary or Management VLAN is
       configured with IP or DHCP
    0000:00:03:18.47 ZTP mairwaveCtrl:AMP server registration started through
       Primary VLAN.
    0000:00:03:18.57 ZTP mairwaveCtrl:IPSEC ZTP: Controller is not discovered
    0000:00:03:18.65 ZTP mairwaveCtrl:IPSEC ZTP: Check-in to Airwave without IPSec
    0000:00:03:18.73 ZTP mairwaveCtrl:sending request to
       https://x.x.x.x/switch_https
    0000:00:03:18.83 ZTP mairwaveCtrl:Added X-Type: Device-Reg
    0000:00:03:18.89 ZTP mairwaveCtrl:Added X-OEM: HP
    0000:00:03:18.94 ZTP mairwaveCtrl:Added X-Mode: SWITCH
    0000:00:03:19.00 ZTP mairwaveCtrl:Added X-Current-Version: WB.16.02.0012_485
    0000:00:03:19.08 ZTP mairwaveCtrl:Added X-Device-Info: SG73FLX6XN,
       9C:DC:71:FD:C9:40, 2920-24G-PoE+ Switch
    0000:00:03:19.20 ZTP mairwaveCtrl:Added X-Group: HP 2920 Switches
    0000:00:03:19.27 ZTP mairwaveCtrl:Added X-Folder: Top
    0000:00:03:19.32 ZTP mairwaveCtrl:Added X-Shared-Secret: XXXXXXX
    0000:00:03:19.39 ZTP mairwaveCtrl:Added X-Device-State: Factory
    0000:00:03:19.46 ZTP mairwaveCtrl:Switch registration failed 35 -
    0000:00:03:19.53 ZTP mairwaveCtrl:Error string: SSL connect error
    0000:00:03:19.60 ZTP mairwaveCtrl:Registration with AMP server failed.
       Scheduling retry in 60 seconds
  • 4.  RE: Airwave 8.2 and HP 2920 Zerotouch
    Posted Nov 14, 2017 01:23 PM
    Does your switch have access to the internet?  It needs to have the time correct to be able to connect to Airwave Via SSL correctly, or you would need to set the time manually.  From what I understand 16.04.xxxx have this fixed.  Can you set the time manually and try to do an activate force?
  • 5.  RE: Airwave 8.2 and HP 2920 Zerotouch
    Posted Nov 14, 2017 01:37 PM
    yes the switch can access the internet and it's getting the updated time, just not within the same timezone as the airwave server so there is a 5 hour different from what I can tell
  • 6.  RE: Airwave 8.2 and HP 2920 Zerotouch
    Posted Nov 14, 2017 01:39 PM
    Just upgraded the switch to 16.4.0009 and it registered fine with Airwave and was added to the correct group.
