Network Management
AirWave 8.2.0.1 login with CPPM as Radius Server not working
  • 1.  AirWave 8.2.0.1 login with CPPM as Radius Server not working
    Posted May 09, 2016 02:04 PM
    Hi!
    I'm trying to get the AMP login with a CPPM Radius Service running.
    The AMP Server generates the Radius Request correctly - CPPM Access Tracker says 'ACCEPT' as login status mathing the correct service, but the AMP Server login screen still responds with 'Login failed Please re-enter username and password'. The same CPPM Service works fine with my switches.
    (The CPPM service rule is just a list/group of IP addresses)
    Is there a logfile an the AMP server, where I can check what's going wrong?
    With regards
    Manfred
  • 2.  RE: AirWave 8.2.0.1 login with CPPM as Radius Server not working
    Posted May 09, 2016 02:14 PM
    Are you returning a management role to AirWave?
    Also, why not use TACACS+?
  • 3.  RE: AirWave 8.2.0.1 login with CPPM as Radius Server not working
    Posted May 09, 2016 02:47 PM
    Im returning the attribute Radius:IETF Service-Type Administrative-User (6) with my Enforcement profile.
    There ia also an attribute type Radius:Aruba Type 'Aruba-Admin-Role (4)' - but I'm not sure which value to choose...
    (maybe I'm close to the solution...)
    Why not Tacacs+:
    Tried to keep it simple and don't like too many CPPM services - Radius works fine with my HPE Provision switch environment. (and don't have much experience with Tacas+...)
    With regards
    Manfred
  • 4.  RE: AirWave 8.2.0.1 login with CPPM as Radius Server not working
    Posted May 09, 2016 02:51 PM
    You'll need to use Aruba-Admin-Role with a role name that matches what you
    have configured in AirWave.
    You may want to consider TACACS+ long term. It's a purpose built management
    protocol with many additional features.
  • 5.  RE: AirWave 8.2.0.1 login with CPPM as Radius Server not working
    Posted May 09, 2016 04:13 PM
    Thank you - I will try to configure ist with TACACS+
    Found also a nice article for Radius:
    http://community.arubanetworks.com/t5/Monitoring-Management-Location/How-to-configure-management-login-in-Airwave-with-CPPM-as-RADIUS/ta-p/266272
    But in the meantime my AirWave 8.2.0.1 server did not finish the Upgrade to 8.2.0.2 sucessfully and does not come up anymore - I will have to fix this first I'm afraid:
    STEP 5: Installing upgrade.
    Mon May  9 20:47:45 2016: Last PID not available VisualRF Engine...
    make[1]: *** [rabbitmq_config] Error 34
    make[1]: Leaving directory `/root/svn/mercury'
    make: *** [upgrade] Error 2
    make: Leaving directory `/root/svn/mercury'
    Stopping Pound:                                            [  OK  ]
    Stopping httpd:                                            [  OK  ]
    Shutting down rabbitmq-server:
    Shutting down Erlang Port Mapper Daemon (epmd):
    failed to kill pid 12213                                   [  OK  ]
    Upgrade aborted.
    Please contact Aruba Networks Support at
    1-800-WiFi-LAN or support@arubanetworks.com
    DISABLED - 2!!
    *** WARNING *** Directory may have been renamed out from under you: /bin/pwd=/root/svn_old/mercury
    [root@localhost mercury]#
    After that I gave it a second chance - also without success:
    STEP 6: Restarting AMP services.
    DISABLED - 1!!
    ...and now for something completely different...
    With kind regards
    Manfred
  • 6.  RE: AirWave 8.2.0.1 login with CPPM as Radius Server not working
    Posted May 09, 2016 04:26 PM
    My AirWave Server is back Online - after the 3rd upgrade try it started sucessfully.
    Strange bevaviour...
  • 7.  RE: AirWave 8.2.0.1 login with CPPM as Radius Server not working
    Posted May 09, 2016 05:54 PM
    Now I'm trying it with TACACS+ - configured AMP for TACACS+ Authentication.
    Seems that I have misconfigured the CPPM enforcement profile, but have no idea what's going wrong.
    I'm getting the following alert on my CPPM Session - the Login status is 'ACCEPT':
    No enforcement profiles matched to perform command authorization
    Tacacs service=AMP:https not enabled
    Is there a configuration example for CPPM and AMP available?
    With kind regards
    Manfred
  • 8.  RE: AirWave 8.2.0.1 login with CPPM as Radius Server not working
    Posted May 09, 2016 05:58 PM
    This is how I configured the enforcement profile:
  • 9.  RE: AirWave 8.2.0.1 login with CPPM as Radius Server not working
    Posted May 09, 2016 06:50 PM
    Try removing the device in the device group list.
  • 10.  RE: AirWave 8.2.0.1 login with CPPM as Radius Server not working
    Posted May 10, 2016 09:43 AM
    Hi!
    That fixed my problem - will have to review why...
    Many thanks...
    With kind regards
    Manfred
