Network Management
Airwave 8.2.10.1 - no usage data after upgrade
  • 1.  Airwave 8.2.10.1 - no usage data after upgrade
    Posted Feb 10, 2020 04:14 PM
    Hi All,
    I just recently upgraded from 8.2.9.1. to 8.2.10.1 and after the upgrade completed (took nearly 2 hours) there is now no usage data showing up on dashboards.
    The usage and client data graphs are flat lined at a value close to the last usage.
    Any ideas? going to try rebuilding onto clean Centos 7 now.
    Scott
  • 2.  RE: Airwave 8.2.10.1 - no usage data after upgrade
    Posted Feb 10, 2020 04:29 PM
    Could we try polling the controller once and see if there is any difference? Does the AP shows client count? Is it only the graph not updating?
  • 3.  RE: Airwave 8.2.10.1 - no usage data after upgrade
    Posted Feb 10, 2020 04:55 PM
    Hi Vishnu,
    We are using IAP deployment so unfortunately cannot poll.
    The AP level graphs were also not working but they were showing client count.
    Scott
  • 4.  RE: Airwave 8.2.10.1 - no usage data after upgrade
    Posted Feb 10, 2020 04:30 PM
    Please open a TAC case to check the logs. The issue is due to RabbitMQ (mainly)or ALC's in the backend that may have got stuck or didn't restart properly post upgrade. Have you tried Restart AWMS from UI under System > Status page?
  • 5.  RE: Airwave 8.2.10.1 - no usage data after upgrade
    Posted Feb 10, 2020 04:54 PM
    Hi Gowri,
    thanks for the quick reply. as you have suggested - a reboot seemed to resolve this!
    Appreciate your assistance!
    Scott
