Network Management
Airwave 8.2.1.1 and Splunk
  • 1.  Airwave 8.2.1.1 and Splunk
    Posted May 17, 2017 01:04 PM
    We have a requirement to start sending logs from Airwave to Splunk.  I see previous discussions in this forum using ClearPass to Splunk. Can we send logs directly from Airwave to Splunk?  Any configuration is appreciated.
  • 2.  RE: Airwave 8.2.1.1 and Splunk
    Posted May 17, 2017 01:13 PM
    Hi
    We could forward logs from Airwave to external syslog server. Navigate to AMP Setup > General> Exteranl logging section to configure.
    Pavan
  • 3.  RE: Airwave 8.2.1.1 and Splunk
    Posted May 17, 2017 02:10 PM
    Thanks for the reply, I will test during the next maintenance window.
  • 4.  RE: Airwave 8.2.1.1 and Splunk
    Posted Aug 08, 2017 03:07 AM
    What type of data are you trying to correlate? You can configure Airwave to send to an external syslog from the AMP Setup -> General page.
    You can integrate Splunk into AirWave using the API so you can lookup a MAC address inside of Splunk and have it show you data from ClearPass, controller syslogs and AirWave.
    Hope this helps, Thanks.
  • 5.  RE: Airwave 8.2.1.1 and Splunk
    Posted Aug 14, 2017 12:58 AM
    SandraLynn
    I don't suppose you have details on setting up this API integration?
    Any suggested starting points?
    Glen.
