Yea I ran into this before also. What I did was changed the dB loss of the walls to match the dB loss in airwave. If there isn't a matching dB loss number its treated as unknown in my adventures with this lol. I don't think the integration included importing the wall types. Just the locations of the walls and matching against what's available on airwave. I will convert all of my walls in Ekahau to drywall before importing.
Dustin Burns
ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022-2023
Original Message:
Sent: May 17, 2023 11:55 AM
Subject: AIRWAVE 8.2.15.1 import EKAHAU backup problem
I try to import the file in subject into my Airwave and everything goes well.
I have the big problem that no walls match and any walls is present into the map but mapped like "unknown" type in Airwave.
I have the lastest version of Ekahau 11.2.0.404.
Any one try the same with similar version or have a similar problem?
Regards
Giulio
