Network Management
Airwave 8.2.2.1 and setting trasmit power on single IAP
  • 1.  Airwave 8.2.2.1 and setting trasmit power on single IAP
    Posted Jun 27, 2017 10:22 AM
    I have IAP205 that I handle from Airwave. When I try to set Channel and Transmit Power on a single IAP on "Access Point" -> "Radio" -> "Adminstrator Assigned" it does not it does not take it, there is no change ??
    Why is that ?
    (IAP version 4.2.4 )
  • 2.  RE: Airwave 8.2.2.1 and setting trasmit power on single IAP
    Posted Jun 27, 2017 10:31 AM
    Are you managing IAPs using template or instant GUI mode? Could share screen shot for better understanding.
    Pavan
  • 3.  RE: Airwave 8.2.2.1 and setting trasmit power on single IAP
    Posted Jun 28, 2017 04:57 AM
    Hi, I´m using AirWave and Groups->Instant config->VC list->VC-> Menu -> Accesspoints See attached screed shot When I do changes here and apply them. It does note change, it does not take it.
  • 4.  RE: Airwave 8.2.2.1 and setting trasmit power on single IAP
    Posted Jun 28, 2017 06:54 AM
    Able to push the configuration, after chaning the values, click apply.
    once we make changes, click Apply button, need to wait for couple of minutes for changes to apply.
    Pavan
  • 5.  RE: Airwave 8.2.2.1 and setting trasmit power on single IAP
    Posted Jun 28, 2017 07:59 AM
    Does not work for me . . .
    I did a change of AP-name in General tab, saved it (but not Apply)
    went to Radio tab, made the changes you se below, pressed Save (but really any response, pressed Apply . . . and waited
    save and apply bottoms is greyed out
    I´ll waited for 10 minutes, nothing happens.
    I go to General TAB again and get the messaged you se in attachment.
    the change of AP name has been done but not signal stringth .
  • 6.  RE: Airwave 8.2.2.1 and setting trasmit power on single IAP
    Posted Jun 28, 2017 08:18 AM
    After apply, are you seeing any options which I have highlighted in  below screen shot. If yes, wait for few minutes and also you could try click on VC, it will show the mismatch config which we are tyring to push, down the page we will see Apply ALL button try click that button to apply configuration.
    Pavan
  • 7.  RE: Airwave 8.2.2.1 and setting trasmit power on single IAP
    Posted Jun 28, 2017 08:54 AM
    I see that my change of AP name was stuck as you describe and I could apply it again. But it was only the the name change that was presented as not applied. The changes on channel and signal was not display among pending changes and status and conf is unchanged. And if I only do the radio changes it will not be displayed as pending at all. Here below is my config history on that VC. It does not show any entry on radio parameter changes at all even if i have tried several time now. I probably need to open a support case on this. I have two separat systems but both same release on Airwave and APs. both system behave the same way 2017-06-28 14:27:22,095 INFO Config 4 Config Result Config Status: success Config Push Result: per-ap-settings 40:e3:d6:ce:8d:6c: OK hostname "TestAP_131": OK exit: OK 2017-06-28 14:26:36,980 INFO Config 4 Message sent { "command": "audit_result_update", "ap_id": 4, "audit_status": "Good" } 2017-06-28 14:26:36,980 INFO Config 4 cluster [SiteLab] has been updated, disabling auto-repair 2017-06-28 14:26:18,700 INFO Config 4 sending delta: { "ap_id": "4", "command": "config_update", "delta_config": "
    hostname TestAP_131
    exit
    ", "hashed_management_password": "0" } 2017-06-28 14:26:12,670 INFO HTTP[1] 4 [] 2017-06-28 14:26:12,669 INFO HTTP[2] 4 Message sent { "ap_id": 4, "command": "request_audit" } 2017-06-28 12:57:49,192 INFO HTTP[1] 4 [] 2017-06-28 04:23:05,518 INFO Config 4 cluster [SiteLab] is not in auto-repair mode, skipping 2017-06-28 04:23:05,518 INFO Config 4 Message sent { "command": "audit_result_update", "ap_id": 4, "audit_status": "Good" } 2017-06-28 04:23:05,418 INFO Config 4 cluster [SiteLab] is not in auto-repair mode, skipping 2017-06-28 04:23:05,418 INFO Config 4 Message sent
  • 8.  RE: Airwave 8.2.2.1 and setting trasmit power on single IAP
    Posted Jun 28, 2017 10:49 AM
    Is this new deployment, could you try clear browser cache and check and also try on different browser aswell.
    If above does not work, try restart IGC service once and check the status.
    #psk airwave.igc
    IAP code 4.2.4 supported in 8.2.2.1 version.
    Pavan
