Airwave 8.2.3 and Juniper WLC MX-800 (FW: 9.1.7.1)
  • 1.  Airwave 8.2.3 and Juniper WLC MX-800 (FW: 9.1.7.1)
    Posted Mar 13, 2017 02:54 PM
    I want to use Airwave 8.2.3 to manage a WLC MX-800 with firmware 9.1.7.1.
    When I add this controller, AMP show error in the configuration of the controller. I need a temple. Where I download os use the template for this appliance/firmware?
    Beste regards,
  • 2.  RE: Airwave 8.2.3 and Juniper WLC MX-800 (FW: 9.1.7.1)
    Posted Mar 14, 2017 05:42 AM
    Airwave currently dont support juniper devices for configuration. Airwave supports it only for monitoring. The software version for juniper devices is validated upto 9.1.0.6.0.
  • 3.  RE: Airwave 8.2.3 and Juniper WLC MX-800 (FW: 9.1.7.1)
    Posted May 27, 2017 06:26 PM
    Hi Vishnu.
    On page 10 of the document “AirWave 8.2.3.1 Supported Infrastructure Devices”, which can be found at https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/EntryId/23720/Default.aspx, it states that several "Juniper controllers and APs are supported for monitoring, configuration, and software upgrades", validated up to version 9.1.0.6.0. Isn't that true?
  • 4.  RE: Airwave 8.2.3 and Juniper WLC MX-800 (FW: 9.1.7.1)
    Posted May 29, 2017 05:36 AM
    It should have been monitoring the configuration, but not actual configuration. I will update the concerned team on the guide. Thank you for pointing it out.
