Network Management
Airwave 8.2.4 all aps mismatched
  • 1.  Airwave 8.2.4 all aps mismatched
    Posted Aug 30, 2017 08:46 PM
    I have recently upgraded to Airwave 8.2.4 and all went well and moved the access points to 6.5.2 which is supported from what i read in the release notes, however once i did that i have 1100 aps all working but they are in the mismatched state.  If you check them there is no mismatches that i can see other that a few waiting to be renamed.  I downloaded and uploaded the firmware for all of our types (205,215,305,315)
    Is there some way to make them all match again?
  • 2.  RE: Airwave 8.2.4 all aps mismatched
    Posted Aug 31, 2017 01:03 PM
    Are the APs off a controller or Instant APs?
  • 3.  RE: Airwave 8.2.4 all aps mismatched
    Posted Sep 01, 2017 08:33 PM
    Hey Rob,
    They are 1 virtual control per site with anywere from 6 to 60 instant ap's clustered and all managed by airwave.
  • 4.  RE: Airwave 8.2.4 all aps mismatched
    Posted Sep 05, 2017 09:18 AM
    Got it, and are you using templates for config or the Instant GUI Config?
    Easy way to tell is when you go into the group, you either see a templates tab or an Instant Config tab as one of the group breakout tabs on the left menu.
  • 5.  RE: Airwave 8.2.4 all aps mismatched
    Posted Sep 05, 2017 10:10 AM
    Hey Rob,
    I am using instant config!
    Thanks!
